Shure Integration - adding another RF device
Wondering if anyone can help. Years ago, I had no problem adding 6 QLXD receivers when AH made that option available. However, now that the DLive is on v1.93, I’m not able to get it to detect a new Shure RF device. I’ve tried disabling Shure detection and rebooting and then redetecting, but it only sees the original 6 devices. I believe that I have all of the network configuration settings correct and all of the relevant devices are on the latest firmware version.
Please refer to the attachment ‘Shure network summary report’ and what is detected in the ‘DLive Wx’ attachment. The IP address of the device which isn’t being seen by the DLive is 192.168.0.116.
The CDM32 MixRack is 192.168.0.71.
The S5000 Console is 192.168.0.72.
I’m trying to isolate the issue. I’m wondering if it is a new bug in the DLive firmware, or if the newly purchased Shure QLXD receiver is defective, or if it is just something stupid on my end.
Just an idea… Is the receiver on the right network mode?
I failed on that many times already.
Thanks, that was my thought at first. Hovever, the QLXD series dosn’t have Dante. Therefore, I don’t see a spot to change the network mode. I guess I can with check Shure support. I was hoping to get confirmation from other users if 1.93 works to add new Shure RF devices.
To clarify, I still haven’t found a solution yet. I presume that since nobody can confirm whether adding a new Shure RF device works on 1.9x, then maybe I’m the first to hit this roadblock. A&H support would like me to open a ticket in order to trouble-shoot it further.
Check if the QLXD is in static IP mode or DHCP. If on DHCP, it won’t show up on your dlive.
this might help: QLX-D User Guide - Shure
Nice try, but not any help for my situation because it’s already using manual static IP as shown in the attachment of the original post. The network summary report shows that every setting is the same except for the actual static IP address ending number “.116”. (and the MAC address is also obviously different)
I even went as far as disconnecting a working unit and then changed the new unit to that IP address and it still didn’t recognize it. It is as if the 1.9x firmware is only remembering the MAC addresses of the existing devices that were configured before the Sennheiser feature was added.
For anyone else stumbling onto this thread, I’ve heard that Shure may have changed the device ID codes on some new units due to supply chain constraints. A&H will likely provide a future firmware update that will be able to recognize the new ID codes.
An indicator is probably the MAC address. My older units start with “00:0E:DD:4B”, whereas the newer unit starts with “00:0E:DD:A0”.
I have a dLive on 1.93 that was just able to detect 2 new ULXD receivers, if that’s helpful.
I can confirm that I have this exact same problem. We originally had 4 QLXD4 units and they were detected without issue. We purchased them >6 months ago. We ended up adding 7 more QLXD4’s a few weeks ago and none of them are detected by the DM48. I have verified that all devices are on the same subnet and configured the same. The router is assigning DHCP and can see the devices from that aspect. I have an iMac connected to the same subnet as well and it can see all of the devices and I actually configured them through WWB from this iMac. WWB can see all the devices without issue.
I verified the hardware ID from the mac addresses are the same across the board 00:0E:DD. Joe, in your description about how Shure may have changed the hardware ID (or the OUI), you are showing a difference, but the hardware ID is the first three octets. The last three are part of the network device identifier. Each device would have a unique ID in the last 3 octets. IMHO, I can’t see a reason why Shure or A&H would be honing in on the first 3 octets of the OUI and the first octet of the device identifier.
Thanks for the confirmation. Regardless of what we think about the issue, the good news is that A&H is already working to solve the issue in their next maintenance release. We just need to be patient.
Trying to connect qlxd (v2.7.1.0) to dlive (v2.03), dlive not shown receivers in the list RF devices.
Qlxd and dlive connected in one net, can see qlxd in WWB
What I do wrong?
QLXD has different network modes. Make sure you choose the right one.
