Shutdown issue since update to v1.1
My console has had trouble shutting down since the firmware update. I thought it was my imagination the first couple of times but tonight I had to tell it to shut down 3 times before it actually did. Each time I hit the shut-down button the displays would fade to the “&” screens for a few seconds before coming back to the main screen. On my third try I finally heard the relay click before the “it is now safe to turn off your console” message was displayed.
Same here. It tells me first that the display can’t shut down. It never turns of at the first time…
I have this same issue on 2 Avantis consoles, I get an error saying: “TouchScreen did not exit cleanly”. I have to attempt 2-3 shutdowns before the click happens and it shuts down correctly.
I’m having the same issue, and the same “Touchscreen did not exit cleanly” error. Running 1.10; can upload logs if needed
It’s a known bug with the current firmware. Hopefully it will be fixed with the next update, but until then you may have to “exit” a few times before the board tells you it is OK to shut down.
I am sorry to necromance this old thread but my Avantis Solo with dPack on 2.01 is still regularly getting a shutdown failure (it will get to the dPack logo but not the “is is now safe to power off” screen)
This happens about once in every 3 power cycles or so.
I see the 2.01 firmware notes claim to resolve this, perhaps partially? Is there any data I could help provide to nail it down?
