The block diagram tells me it should be possible to route the signal generator to an input channel - but I can’t find a way to achive that.
The signal generator doesn’t show up in the I/O patch (neither on the desk nor MixPad) and there’s no option to select the generator as an input in the processing menu of the inputs, either.
Am I blind?
You can find it in the manual on page 24.
Cheers mate. That’s very well hidden indeed.
Cool. I had no idea. I can see that being useful.
For fun, setup a 80Hz sine wave on the signal generator, route it to an input, then put a hard gate on it, and trigger it from the kick drum.
I would use something between 50 and 70 Hz for starters and adjust to taste. Really helpful if you have a badly tuned kick drum and a D112 only.
I’d also use something in the range of 50-65Hz for kick. Also some gated white noise in case no SD bottom mic
Good to know - i was also kinda “blind” and had not properly RTFM
