Hey guys.
I’m not getting any output signal when routing Main L/R to output 11-12 on the SLink AR2412. The IO looks as it should on the diagonal and the other outputs works fine. Any suggestions?
Have your tried swapping your routing around? Putting the main L/R buss on some other outputs (1-10) and some other busses on outputs 11-12? Does the LR buss work on other outputs and the other busses stop working when routed to 11-12? If so, it points to it being a hardware problem with the stagebox. You should contact your distributor for further help.
On the other hand, if changing the routing changes the results (ie outputs 11-12 work with other busses, or the Main LR doesn’t work on other outputs either), then it is a “settings” issue in the console somewhere.
