Slow response on some buttons
Often when I’m mixing, because I work fast when I change the buttons of AUX mix unresponsive, and I have to wait a while to make the switch. Also if I push in LR. And often with the buttons gain, pan and custom 1 and 2.
I also noticed that sometimes the rotary control to adjust a bit PAN moves all right, and that’s a serious problem too.
Has anyone noticed this mismatch? Thank you.
GLD-80
2412
84
Hi Perdut
Are you running the latest firmware v1.02?
If you have a reproduce procedure for the Pan jumping to the right side please contact technical support with a copy of the event logs and how to reproduce this problem.
https://www.allen-heath.com/uk/support/Pages/support.aspx
Regards
Sam A&H
Yes Sam, I update to the new firmware immediately appeared. Event log does not show these events. Do you know of slow changes in MIX? Thanks
GLD-80
2412
84
