As the title suggests, having control of the “off/on” for the Tube Stage by means of a soft button would be nice.
While a vocalist is singing a chorus that had a dirty sound in the album version, I’d love to be able to punch it in/out quickly instead of having to use the touch screen.
Could probably do some smart filtering with a scene and safes, but would be much simpler to just have a hot key.
well I remember measuring tube responses, to draw curves for them, in my first electronics class.
at least back then our tubes did distort quite a bit.
you could keep the drive low and use feedback to help limit the distortion, but they had significant distortion.
The even harmonic distortion is used for more of a very subtle effect and it can be a good effect in the right place.
When I was coming up back in the 60s the goal was to eliminate distortion, noise, miscellaneous artifacts, yada yada,
so we could achieve HIGH FIDELITY as good as the original - at least within what we could measure meaningfully.
Now that better circuits and digital techniques have eliminated the problems it seems like people want to bring them back again.
Nostalgia ? Or they are so used to hearing problems they think they are normal ??
Maybe the newer folks are so used to hearing good sound they just want to hear something different.
Or could it be just to fill the need to be doing something to the soundinstead of doing nothing to it.
a slightly distorted bass guitar signal cuts better through the mix
you could hear a saturated voice signal much better
electrical guitars use distortion
Rhodes piano sounds are distorted sometimes…
so it all depends on the target…
a talking person needs no saturation or distortion but could benefit from a bit coloration from tubes as well…
adding a bit K2 or K3 could enhance many sounds
the Tube Stage is very flexible on this,
slightly saturated to high distortion is all possible…
If you have spare inputs, you could always double patch the vocal input and have a “clean” channel without the emulator and a “dirty” channel with the emulator. Then you could mix the effect to your tastes using the two faders.
But I totally understand you desire to simply this with a soft key function and agree that it is the best option (although you are correct that you should be able to do this with a load scene softkey - although you will need two keys to do this - one to turn it on and one to turn it off).
