Can anyone recommend a soft carry case for the SQ6?
I have a QU-16 with the A&H soft case which works very well and would like a similar one for my SQ6.
Also, which flight case do people prefer for the SQ6?
Cheers, Chris
Cheers, Chris
I have a QU soft case for my SQ5. I have never seen a soft case for an SQ6 though.
Allegedly:
Thanks for this information. I had seen this Gator case and I have a number of their hard cases. I have read a few bad reviews of it though, consensus being quality of construction being poor. It does look like the only soft case out there for the SQ6 so I’ll give it a go ![]()
A&H has a Softbag for the QU16. This Bag can also be used for the SQ5.
But I have have never seen a Softbag for the much bigger QU24
At least in Germany at Thomann it’s much cheaper - and no bad reviews.
Yeah, I didn’t look much into it. Just wanted to see what might be it there. Sounds like you might have more luck searching for a soft bag that suits the Qu-24 since they appear to be interchangeable with the SQ6?
Indeed, I’m wondering if the larger QU and SQ6/7 are too heavy for a soft case.
I’m assuming it’s exactly the same bag.
But if you’re advertising it for A&H, you can charge a little more.
Why do you think that?
The manufacturer designed it for exactly that purpose.
I’m going to get a Gator case and see how it goes.
I say it because I know how the QU-16 is in the A&H case and the SQ6 is quite a bit larger and heavier, just that, no evidence as it were, just a feeling.
