Yes!
or softcontroll of wet dry on effects…
My first post!
All the best
Yes!
My first post!
All the best
+1 would be a great PANIC button when waves server crashes.
This would be a great feature to use when needing to switch on/off auto tuners.
i too would like to have the ability to recall a scene that only effects insert on/off state of all channels, auxes, groups, busses, & matrixes (waves IO is patched to these)
the only alternate thought i had would be a softkey to disable/enable the actual IO port (this could work if disabling the IO would cause the inserts to bypass due to NA signal path)
+1
+1
Having to go 2 screens deep in a typical scenario to be able to disable an insert makes using FX slots as insert (why burn a bus if you’re only using it on one channel) much less useful. Especially when just about everything else in the processing path has a hardware enable/disable button on the console.
It’d also be nice to have the same sort of enable/disable option for the Tube Stage preamp plugin as well.
+1
please make this a soft key or a separate recall filter
I’d love this. Just had a show where the inserts I use on USB crashed…a panic button like this would be awesome to have.
I assume it would be done in a way that you can toggle an insert on and off on a single channel/bus/group/matrix, but I’d make do with that, since I mostly use inserts on groups, so I’d leave the first 4 softkeys for this for example, and then just press all 4 quickly when there is a problem.
