I would really like the Sel Mix PAFL Scene softkey option to be able to trigger another scene when the softkey is deselected.
Use case: I use the Sel Mix PAFL Scene on various softkeys programmed to select Aux and FX mixes and recall IP8 sends on faders for the same buss with the embedded scene recall. This works great when the SK is pressed on - but would like a different scene to be recalled when the SK is turned OFF to return the IP8 back to main fader levels.
That way the IP8 will behave just like the console faders - change to sends on faders for the selected buss, and return to mains when SK is toggled off.
Nice idea. But then for IP8 softkeys as well, which are still limited compared to the consoles softkeys.
Agreed! Yes would also like similar softkey actions on the IP8 - and perhaps if Macro commands can be set on softkeys and IP8 also as others have requested. One step at a timeā¦
