Hi to everyone, I just would like to share some thoughts I have about GLD.
Regarding the stagebox AR2412, when using it with one AR84 (to have inputs 1 to 32) if I chose to put the AR84 underneath the AR2412 (so the the input number follows 23, 24, 25, 26…and the outputs 11, 12, 13, 14…) then I have to link the two stageboxes with a cable that runs over the other connectors (Monitor and Dsnake) in the AR2412.
Is just a matter of design, if you switch the “DSNAKE” connector with the “EXPANDER” connector you can link both stageboxes with just a very short CAT5 and it would be much safer [
Is there any way I can save a preset of Softkeys? so every time I do a new show I can load “my softkeys settings” and have everything how I like?
Is it possible to make bigger the keyboard in the login screen? is very small and there is no other relevant information at that point…just type the password.
Is it possible to make bigger the RTA?, it could be bigger and easier to see, lots of free space in that screen also.
Is it possible to create one softkey function that displays the RTA for the MIX selected? and the same with the Input selected (but it would be great to have them in 2 different softkeys, so by clicking once I have direct access to the RTA of the channel or mix I´m working with.
Is it possible to make one sofkey function that allows the user to assign the tab Overview to that softkey?
Many thanks!
I have to say i´m very very happy and impressed with my GLD112 [8D] and way happier with the support from A&H since I bough the mixer you released one software udpate, 2 apps, so Its great to feel that there is always something happening to improve the system and keep the users feeling happy.
Everything louder than the rest!
