Hey all,
I’ve been scrolling through these forums already and many answers are solved, some not so clear yet. But this seems like a very nice community with many people jumping in. Nice to see.
At the end of last year I have made the decision to go more to hardware then doing everything inside Ableton Live with plugins. I now came to a point that my audio interface is out off analog ins. So instead of buying an expansion through ADAT, I thought why not a digital mixer like the Allen & Heath Qu-16? Then I will also have the hands-on experience when mixing the tracks. The mixer will be used only for studio use with hardware synths, drum machines to make EDM style music.
But it’s expensive so I want to do my homework and not get a cat in a bag. ![]()
My system: I’m running Ableton Live 9 on a Windows 7 64 bit. So here are the questions:
- How stable are the Windows drivers? Any problems occured?
- I never worked with Allen & Heath before. How is the support?
- How is the build quality? Will it reach 10 years or more (studio use)
- According to the brochure, the QU-16 can send 24 and return 22 channels through USB into a DAW (my case Ableton). Is this simultanously? For example, can I send the analog ins from my hardware synth into Ableton, process them inside Ableton with some plugins, and return them into the Qu in realtime for further processing?
- Continuing on the point before, with that many IO’s, what is the expected latency?
- For the build in compressor and gate: Can you do side-chaining on them?
- How many internal FX does the Qu have? I see 4 slots, but on the side only two buttons?
To end, I’ll try to explain what I’m truly looking for:
I want to have a mixer to have more hands-on and use Ableton more and more only for the midi. But for now, I still use a lot off plugins like Native Instruments Massive and others, so I don’t want to loose these. Being able to send them back into the mixer and work hands-on from there would be a dream. But while doing so, I don’t want to give up any off the analog inputs. When I look at my tracks now, I’m rarely go beyond 24 audio tracks in total (hardware and plugins).
Also for some sounds, the normal route off gate, compressor, EQ and a combined effects channel isn’t good enough. For some sounds I want to be able to send it to Ableton and use much more complex effect racks on the sound to get those special results.
And last but not least: I want all the above in real-time. I do NOT want to record sounds, and then work from there. No! I want to be able to adapt all sounds continuously in realtime. That’s my workflow and I can’t go another way.
So my concern is with the USB latency. I’m sure I can stream to ableton, then go back into the mixer and hear everything to my speakers. But what will the latency be between it all? Can I use the inbuild latency adjustment in Ableton to get around this problem?
A big thanx in advance
