in the rock´n roll history i learned never switch off the amps and desks at a live open air festival, because of water damage inside the unit´s (condensation).
i work at a festival about 4 days, i hope there will be no problem!
greetings from hamburg
I usually leave my iLive on if out doors, always have. Just make sure it does not get too warm, never had a problem so far.
Sometimes my surface seems to lose synch with the touch screen… like pushing select on the channel strip doesn’t have an effect.
Have you looked at the error logs to see if that gives you a clue?
of course, i do have a look for the temperature
Hi Adam
Does the touchscreen go to the lost connection page or does it reamin connected but freeze up??
does this happen often, if so are there any specific conditions when the problem occurs?
Regards
Sam A&H
quote:
Originally posted by Stealth
Hi Adam
Regards
Sam A&H
I have same problem ones when i have disconnect the surface from mixrack. After i reboot the surface the sel button doesnt work. I must powerd down surface and powet again and everything was ok. I check at wednsday at gig is this problem repeat.
Mario from Poland.
I will have a look at error logs – it doesn’t go to the “lost connection” screen … and it doesn’t really freeze up, the meters on it work fine - it’s just the select button doesn’t seem to select the channel (on the surface, or on the touch screen).
Now that i think off it. I had the same problem once after upgrode to 1.61 . I connected the rack with the surface to test the system. every think was fine. After a two hour brake i came back in the venue and the surface showed connection lost. so i reconnected an went on. But ofter i showed the guest engineer how easy the ilive is the select button stopped working[
]. Every thing else seemed to work ( mainaudio,faders, meters, audio from surface to rack(CD)). i rebooted the surface and had no problem since. I think the problem only exist after a reconnect after lost connection.
Now on 1.63 and no problems.
Lieven
T112/IDR48
Save a tree, eat a beaver
Hi All
For those of you having issues with SEL keys not working sometimes, please update to firmware v1.63. There are some known issues with SEL keys in 1.61.
Regards
Sam A&H
