So we moved from an iLive to a dLive and we use the Speaker Matrix on the iLive for our small system.
Now I see, this is not available anymore in the dLive.
Is this coming back ?
Why don’t you just create your own by adding matrices?
We did this for our centre hang, in-fills, out-fills and infra-subs on top of the LR main bus.
this is not the same.
for example: in the dLive you can´t define a 24dB Linkwitz-Riley Lopass-filter.
+1 from me for the Speaker Matrix - or, as I said before, to have an option of Hi- and Lopassfilter in the mixes. please! ![]()
I really miss this function – While I don’t think a mixing desk should be the crossover/ processor for the main speaker system, it was so handy for so many things.
Bunch of matrixes will do. Use like this all the time- stereo mtx for main PA, mono for subs, mono for delays, another mono for frontfills.
ddff
yes the speaker matrix would be very helpful in some cases… and adding matrixes is still not the same
yes, as I had already written above, adding matrices is not fitting the solution!
in the matrix so far there are unfortunately only very simple filter options, this is not comparable to the “Speaker Matrix” from iLive!
but it would be enough if you had better filtering possibilities in the outputs.
another idea could be to call up an 8-band PEQ as a GEQ-model ![]()
Well, speaker processing (advanced filters, limiters and voicing eq) is done in speaker processor and is under control of PA engineer. In the mixer you have enough tools for most situations. If not, Lake is just 1RU ![]()
ddff
I know what you mean.
but it also depends on the job you do. the dLive is very flexible in its use, which I have also taken care of very small events.
for example last weekend a very well paid half-playback-show for 60 important guests. so I had to bring a controller for the small PA. in iLive, this could be solved with onboard equipment.
it’s not about outsourcing controllers to the console in general. I hope you understand now what I mean.
