Can I split every inputs into two separate channels? so that I can have separate eq and dynamics for FOH and Monitor mixes?
Example, First two layers for FOH with separate eq & dynamics and next two layers for Monitors with separate eq & dynamics.
Is this possible?
you can patch every input to every channel strip and you can patch one input to every channel strip and evrething in between
and you can configure every layer as you like
inputs, outputs, DCA where ever you want it
Yes that can be done but my question here is can we split the every input? With different eq and dynamics? Working like tow Mixers for FOH and Monitors.
I would like to know that as well !?
what was not clear on my answer?
you have 64 input channels
and it is possible to use an input socket on two or more channels
so if you have 32 inputs you can use every input on at least two channels
one dedicated to FOH and one to MON or broadcast or whatever you name it
you only have to patch it
but the multi-surface mode from dLive is not possible at this time
Thank You Steffen.
Hope there is feature like tielines like in SQ.
