Good morning everyone, I did a quick search but I don’t think I found anything.
I recently bought an SQ5, which will soon be replaced by an SQ5+ that I’m currently waiting to receive, and I downloaded the new SQ+4You app.
I noticed that, just like in the original app, it doesn’t seem possible to add effects FX (like reverber o delay) to the aux mixes through the app.
Is there any specific procedure to enable this, or is the feature simply not available?
If it’s not available, I think it would be worth requesting an upgrade, since singers often want to hear themselves with a bit of effects in their monitors as well.
Do you think this could be possible? Has anyone ever brought this up before?
Tks
I believe there would be a huge “outcry” if this weren’t possible. )
To do this, you simply need to mix the assigned Returns of the desired FX into the respective Aux mixes, just as you would do also in the Main LR. (See also the images.)
In principle, you could do the same within your “Groups” in SQ4You.
Perhaps, as a supplement to this, the following image.
Credo che non avevo proprio visto che si potesse aggiungere “send” e “rtrn” dall’app.
avevo verificato che fosse possibile dal mixer, ma non trovo questa opzione dall’app.. Bastava scrollare un po per verificare che erano presenti altre opzioni.
Attendero che arriverà il nuovo SQ5+ per poterlo provare.
grazie della tua risposta.
I think I simply hadn’t noticed that it was possible to add “send” and “rtrn” from the app. I had checked that it could be done from the mixer, but I couldn’t find this option in the app. I just needed to scroll a bit to see that there were more options available. I’ll wait for the new SQ5+ to arrive so I can try it out. Thanks for your reply.
