SQ 5 and OBS [Apple]
Good evening everyone,
To ensure streaming the stereo output of the matrix is associated with the USB 7 & 8 output.
In windows, when I choose the SQ 5 OBS allows me to choose which is the source I would like to use (7&8 USB). We recently switched to Mac and there, no more choice. OBS seems to recognize only channels 1 & 2 as input and output.
Note: in a DAW all USB inputs and outputs are well recognized.
Can anyone tell me :
  1. If the problem comes from OBS or Apple?
  2. If you have a solution
  3. Bonus: is there a tutorial to set up the SQ in OBS?
Thanks in advance
Yohan
OBS
this is a new feature I think… it had the same limitations in Windows before
an aggregated device could be a possible solution
I had some limitation with a Focusrite Scarlet 8i6 but none with a SQ which I used since November 2020. Yes, It’s very great that we can you the USB input.
Check out Rogue Amoeba’s Loopback.
