I’ve had my SQ5 for a few days now. Still at the setup/experimentation stage. Have been playing music from ipod via ST3. Output through AR2412 and AR84. This afternoon main audio out dissapeared for about 3 seconds and I could still hear the music coming through the headphones. Will report to A&H.
I used my SQ6 (V1.1) several times with an older AR2412 (the ‘prince’ version) and an AB168. The Mixer is connected to the AR2412 with a 70 meter long Klotz cable (unshielded) or a 50 meter long Thomann cable (shielded) and the AB168 is connected to the AR2412 with an 15 meter long Klotz cable (shielded). I use an desktop UPS on FOH and another on the stage for the two stageboxes.
No issues so far, after approx 10 jobs, most of them with approx 24 to 32 inputs and 8 to 12 outputs.
Middle of the show audio loss for 3 seconds with the ar2412
We have passed this report on to our software test team to look into, however they haven’t been able to reproduce the audio loss with the AR2412. They have had multiple units on test for 2 weeks now without any dropouts, so if you have any more detail of your setup, if anything in particular was being used at the time, cable length/spec, power setup, can you please forward it in a ticket at support.allen-heath.com
Multitrack recording: Buttons do not react anymore at the end of recording.
To play back a multi track after being recorded the file needs to be selected. So after pressing stop, press the Touch to select track button, select your recording and press play. I’ve fed this feedback to the team.
Libary’s only usable withing the show. No option to export (only copy/paste with laptop)
The Library and USB data aspects are being looked at and added to in future firmware releases.
Brightniss of display is stored in showfile…
The show file stores all user preferences such as Chromatic channel metering setup, so this is unlikely to change.
After error nog log file.
The SQ has no real time clock to produce log files like GLD and dLive.
If there’s anything else I can help with please feel free to include it in a ticket with more details regarding the audio loss.
So that’s why there is no Date & Time stamp on the SQ-Drive recordings.
Looks like every audio file will show 1/1/2017 1:01 AM … making identification and sorting a challenge especially since the file(s) can’t be given a name either.
