I’m unable to connect to my SQ-5 mixer with either the SQ4You or MixPad apps. The mixer name shows up in both apps but when I press “Connect”, it shows “Connecting…” for a while and then displays a failure message with “Failed to connect: socket sync timeout” (in MixPad) or “Failed to connect: scene sync timeout” (in SQ4You).
I tried using both DHCP and static IP addresses for the mixer, with the same result. I also tried rebooting the mixer and reconnecting multiple times.
I tried connecting from both my Android phone (with SQ4You and MixPad) as well as with my Macbook Pro (with MixPad), and got the same error messages each time.
I’m using a GL.iNet router, with my phone and Macbook connected wirelessly to the router’s own network. The mixer is plugged into the router using LAN, and shows up as a connected device. I don’t think this is significant, but my router displays an asterisk (*) when showing the mixer as a connected device, instead of the name I entered in on the “Setup > Network” screen on the mixer. However, I see that name in the apps when I’m trying to connect.
My SQ-5 firmware version is 1.5.10 r4132. On Android and Macbook Pro the SQ MixPad version is 1.5.4, on Android the SQ4You version is 1.5.1.
Could someone please help me figure out how to get these apps to connect to the mixer? If this doesn’t work I will likely need to return the mixer and find a more reliable setup.
Deepak
