SQ 6 Audio Dropping when using USB inserts
Hello!
So our church uses the SQ 6 for our live stream mix. All of our channels are sent over SLink from our FOH console (Avantis) at the preamp level. We are using a computer with the SQ 6 over the USB B port to apply auto tune to vocalists via the inserts on each channel. However we are having an issue where everything works fine but sometimes when we move the faders the audio will stutter and then completely drop out. Is there something we are doing that is causing this?
