SQ-6 can't acquire IP address from router - network port broken?
SQ-6 just arrived. Going thru various tests, everything works fine except network port - forether stuck in Acquiring step in DCHP mode
With DHCP off, SQ pad doesn’t see the unit.
Router Lynksys WRT54G - using it with QU-24 and XR-18 without any problem
FW - 1.3.2.
Link led is on and steady
Rebooted router and unit many times, swapped cable, of course.
Laptop logins to router just fine.
I do hope it’s some simple thing I miss, can’t believe port on new unit is not working
I saw people complained about connection stability in 1.3.0, hope it’s been fixed
Hi Andrey,
Choose other router (NEW)
Linksys WRT54G is very old.
Csumi
I was hoping for that - nice try :(.
Just did more or less recent Netgear, no luck. When connected unit is not displayed in router wired connection list.
And , BTW, router is router - if device can’t be seen by router by wire and can’t acquire ip - something is broken, no matter how old router is.
to make things clear
you are using DHCP and it is switched on in the console and after that you reastartet the desk?
Some obvious questions:
  1. Your laptop is set for DHCP and acquiring an address, vs static?
  2. You are plugging into the network port, not the SLink port?
  3. You are looking for the IP address on the status page, not the network page. When the network page shows “DHCP” it never updates for an acquired address, that is always on the status page. (bit me the first time)
  4. The DHCP advertisement is “consistent” - the IP/Netmask/Gateway all agree? I don’t know if the SQ validates it, but I could see it rejecting something that is inconsistent. You wouldn’t see this unless you tried to do WAN routing through your router. The XR18 has such a poor network implementation I wouldn’t trust it as a reference point.
  5. Set the console to a static address and see if your laptop can ping it.
Yes, I don’t need DHCP, but DCHP allows me to check connection quickly without using tablet
And, BTW, unit never shows up in router wired connection list
Jay,
    Yes
    Yes, SLink is taken with AB2412 :slight_smile:
    Yes, I’m checking this Diagnostics page with all unit’s states
  4. The DHCP advertisement is “consistent” – the IP/Netmask/Gateway all agree? I don’t know if the SQ validates it, but I could see it rejecting something that is inconsistent. You wouldn’t see this unless you tried to do WAN routing through your router. The XR18 has such a poor network implementation I wouldn’t trust it as a reference point.
    Yes, I didn’t really touched the defaults, it’s on 192.168.1.1 subnet
    That’s a good test, shame on I didn’t do it, thanks
Thanks to all of you for good ideas, I just called Sweetwater tech support and they sending a replacement unit.
I still suspect there is something logically wrong with old unit - just can’t imagine A&H QA team let it pass with such a malfunction, but if new unit works fine I can forget it.
Thank you, folks
Update : received new unit today - works as should. Seems like A&H quality control needs some improvements.
Thanks to all.
wow
but it can happen
have fun with the new one :slight_smile:
This might come out from your router and you will have to check it if you want to find this out, or this might be because you are using a VPN. To be honest, I heard about this issue a lot of times and in the most of the cases this was caused by the VPN people used. This is a very interesting question if the VPN worth or not, and should you use it or not. I’ve read a great article last night about strong and weak point of the VPN and this is really interesting. By the way, you can find this article here https://www.router-reset.com/are-vpns-worth-money-or-waste and you will understand if you need to use your VPN or not. I think I will use, but you can have your own opinion, and both of us will have its own argument
