SQ-6+ freezes during live use while recording 32 channels
Hi everyone,
I’ve now had two occasions where my SQ-6+ froze during live use while recording 32 channels at 48 kHz.
I’m not sure what caused it, but I wonder whether the workload could be a factor. The SQ runs internally at 96 kHz, so could converting the recording to 48 kHz add enough processing load to contribute to a freeze? I’m also wondering whether the USB drive’s sustained write speed could be involved.
These are just hypotheses. Has anyone else experienced this, or can you suggest what I should check? In particular, I’d be interested in recommended USB drive specifications and whether there’s any diagnostic information I can collect if it happens again.
I can add the firmware version, drive model and other details if those would help.
This is a known bug and already under investigation.
Is this true, Steffen? It seems to me that A&H has steadfastly refused to investigate anything having to do with the flaky SQ USB recording issues. That function has been a problem for many, many years.
D.
I believe this due to the USB Drive you use - I am using a Samsung T7 ssd without issue for a year now - what type of drive do you have?
You might be right about that. Still, even if there is some issue with the USB Drive, the console should never freeze, so this is still a (somewhat serious) bug.
I noticed that USB drives that aren’t compatible with Allen & Heath do cause the Mixer to lock up - it might also be a bug - but if you use the right drive it doesn’t happen - at least for me.
Did you during that period really use an SQ+ - the same new series that the original poster is using?
I am fairly certain that this new issue, where the SQ+ screen freezes, is distinct from the long-standing, typical A&H problem involving data loss during recording to many types of USB storage media.
Hi erveryone,
I experienced the same issue last weekend with my SQ5+ (FW 2.0.3) while multitracking @48kHz48kHz: Display froze completely, but all the rest of the desk still worked fine (Faders, Encoders, remote App…).
I remember the same Issue with SQ.
would also consider this to be a bug, as there were absolutely no Dropouts, and the Audio recorded also seems OK. it´s really “only” the display freezing. Better bring your tablet with the remote App running, if you´re multitracking to USB, so you make it through the rest of the show…
The USB stick used was a random one, by the way.
Hope you guys get this solved soon:)
