Since yesterday I have the problem, that on my SQ-6 the Processing button does not respond anymore.
I was preparing the scene for the concert of a Bluesband, and while doing the setup, I noticed,
that I had to press the Processing button increasingly more often, when I wanted to change back from Routing to Processing
At last the button was non-responsive. It does not feel like a mechanical problem, the ”press-feeling” is normal and not different to the other buttons.
After rebooting the mixer, the Processing screen is displayed and the green button LED is lit and as long as I do not press the Routing button, I can reach every processing screen.
I reinstalled Firmware SQ-6UPG_1_5_10r4132, but this didn’t change the behavior.
My questions now:
– do you think, this seems to be a hardware-problem ? (and who could fix it – the German distributor Audio-Technica Deutschland ?)
– should I try a real hardware-reset ?
– is there any possibility to program any other SoftKeyes to function as the Processing button ? (as a work-around)
Otherwise, I will probably have to protect the routing button against unintentional pressing (cover it).
I would then have to operate the routing function via the iPad if necessary.
Thanks a lot in advance
T.Kap
@Keith: sorry, sent you this initially as a private message, subscription was missing…
