Hi All!
I’ve an issue with a stereo input on an SQ-6 which has apparently different gains on left and right - meters with PAFL show right is significantly higher. Adjusting gain or trim, as you would expect, adjusts both channels together (Local 21/22 in this case). I’ve checked I/O patching and it shows it as a stereo pair, also confirmed this in the stereo inputs config. Input is not being used in other channels too, patching is only to the channels 45/46 in this case.
If I swap L/R input cables over the right hand input remains much higher.
I also tried making mono or reducing the stereo width and this does makes the levels the same (or closer).
In summary, why can’t I get the gain/levels on both channels in the stereo pair to be the same?
Thanks all!
The levels on both channels were different before you made the stereo connection
the settings from the preamp section where not taken into account
@churchy
It can be a benefit to adjust the gain of the two sockets independently. Not always both signals of a stereo source have the same level. But if you want to bring both gains to the same level you have two choices. 1) make the stereo channel to two mono channels, adjust the gains of both sockets and make them again to a stereo channel (but that means you will have two short periods of time when all audio is muted) or 2) assign one of the to sockets as the input socket of an unused mono channel and adjust the gain of the socket on this channel.
So if I change the channel configuration to two mono channels, assign the new (was right) channel to a spare input, set the pre-amp gains to 0dB on both channels, make it a stereo pair again, then all should be well?(!)
So why are the gains AND trim for both channels on a stereo pair not exposed to the engineer? That’s really obscure!
Thanks for your input (no pun intended), I’ll give that a try tomorrow…
You have the two options I explained previously. You have to do the one or the other. It is not required to do both.
