I am using the usb on the front and I recorded some songs but when am listening to them now its all stuttering and almost like skipping. What could’t be the issue?
Which version of the SQ6 firmware are you using and is the USB stick fast enough to record the data?
Dave
Bonjour, depuis la dernière mise à jour, je n’arrive plus à utiliser les clefs usb ou disques durs qui me permettaient de faire des enregistrements multipistes corrects auparavant, j’ai des erreurs qui apparaissent sur le compteurs pendant l’enregistrement où l’enregistrement se bloque et se fige. Et vous quels sont les "symptomes " pendant vos enregistrements ? CDLT
I using a Samsung 3.0 flash drive with 128 . Same one I’ve been using for a while now and only after after the software update did I start having this problem.
Cause and effect for the firmware update?
There is a service release of 1.6 that is now available to fix the more serious faults. Have you updated to the service release?
If that doesn’t fix your problem, raise a fault report with A&H.
Dave
The USB recording system onA&H consoles is unfortunately not very robust. Some USB sticks work, and others don’t, even the same kinds. All you can do is try them until you find one that works. The only indication that it’s dropping samples is an error count on the recording page.
Recording via USB to a laptop is much more reliable.
