SQ and IP8
Will the IP8 work with the SQ mixers?
I thought I had seen that question earlier, but was unable to find it now.
Hey Art,
IP6 and IP8 use with SQ is not currently supported, but has been requested quite a bit, so it is being looked into!
Thanks! That would be a good thing!
+1
+1, it will be good in places of remote mixing, especially for monitors since SQ has 12 stereo out.
from a person that likes instant access to surface this could be ideal.
I want to use SQ and IP8 in combination.
I am a playback engineer.
Send MIDI from the IP8 button.
I want to use MIDI as a trigger to AbletonLive on a Mac connected to SQ through a console.
During rehearsal, you can control the faders from S8 to SQ from a distance. In addition, you can play sound source with multitrack from USB via Mac via SQ USB.
I want you to make it happen.
+1 I’d buy IP6 and IP8 if I could use them with my SQ
Just wanted to add to this, I am also wishing this was possible, would buy an IP8 in a heartbeat if it worked with SQ.
