Hi, I’ve just purchased the All-Add-Ons Bundle for my SQ5. Haven’t had a chance to play with them yet but I’ve got the perfect little pub gig coming up tonight to try them out on (drums/bass/keys/git/vox). Anyone got any recommendations on what works well on what instruments?
Thanks in advance!
Congrats on the upgrade! The SQ add-ons are definitely worth experimenting with.
For drums, I’d recommend trying the Peak Limiter 76 on your kick and snare for some added punch, and the Bus Compressor on your drum group to glue everything together. The Mighty Compressor is another good option for drums, particularly kick and snare, when you want something punchy and aggressive.
For bass, the Opto Compressor is great for smooth, consistent dynamics and the Peak Limiter 76 can work well if you’re after something more aggressive.
For vocals, I’d try the Opto Compressor for natural compression, or the 16T if you want something with a little more character.
For keys and guitar, I’d start with the standard processing and experiment with the compressor models as needed.
My biggest recommendation, though, would be to avoid changing too much during your first gig. Start slow with a few compressors, get familiar with how they respond, and build from there depending on the genre, room, etc. Use your ears; they are your best friend, and adjust to what sounds good to you!! Cheers!
I’d also recommend, if you haven’t already, registering your mixer on the Allen and Heath website, so you can get the free tube stage preamp!
https://www.allen-heath.com/product/tube-stage-preamp/
