SQ Drive FILE MANAGEMENT
Hi, new to SQ and love it. Playing with SQ Drive I see it desperately needs the ability to manage the recordings, which should not be difficult to implement. Some suggestions:
  • If we can’t Rename the files, at least add a Tag feature, which inserts a tag to the file properties, visible as a ‘Note’ we can edit to see that file SQ-0014 is a song, date, reference track, whatever.
  • Basic file info, like length, possibly creation date, so we can easily determine the pile of short junk files from the files we want.
  • The ability to DELETE those junk files we don’t want.
  • The ability to LOCK or Flag files we want to keep and protect from deletion.
None of this should be particularly challenging for the brilliant engineers at Allen & Heath, and would be HUGELY helpful to those who utilize SQ Drive.
Thanks.
Yes, but some will not be along for a long time - anything that needs automatic date & time stamps will need a real time clock on the SQ, and there isn’t one.
There’s no clock in the SQ, so no time stamps.
You can change the recordings’ file names by editing the thumb drive on your PC. All caps, ‘-’ sign for spaces, long names. They read fine in the SQ after that. I have all my sound check music on a stubby drive, so it’s always with the SQ. If I worked with one band, I’d have a virtual sound check file on there too.
BTW, I couldn’t figure out how to get songs copied to the thumb drive to play on the SQ. I had to re-record them on the SQ. (Then rename them back on the PC). No biggie, just annoying.
Regarding timestamps: A&H introduced in firmware version 1.6.0 an feature, that the console receive a MixPad’s timecode when connected, which is then available for timestamps the SQ Drive recordings.
Renaming and deleting recordings should be a matter of course and has been requested many times in this forum - unfortunately without implementation so far.
I don’t understand why it’s not possible to record less than 16 channels. If I’m only using 5 channels, for example, then why record all 16 channels? It just wastes the memory space on the card.
Depending on the sampling rate, the SQ can record up to 32 tracks.
However, it will only record the tracks that you patch in the I/O patch - so, if desired, also only one.
