SQ-Drive Multitrack patching
To record stereo on my pendrive I go to I/O, Output Patch, Outputs, Mix Out. Then I select the USB tab and click on Main L and R assigning these to USB 1 and 2. When I go back to Utility/Stereo I can see that the peakmeters are assigned to Main L&R.
I assume it’s the same process for 16 tracks recording so I go to I/O, Output Patch, Outputs, IP Direct Outputs.
Then I select the USB tab and click on the channels I want to record assigning them to USBs 1-16.
The thing is when I go back to Utility/Stereo I cannot see that the peakmeters are assigned to 16 channels.
They’re all empty except the first two that are assigned to USB 1 and 2.
Can someone tell me how to do this please?
Thanks in advance
Mine did that too, but as soon as I pressed record all tracks filled up with the patched channels.
OMG you’re right!!!
Thanks a lot!!! I LOVE YOU!!!
:wink:
