Insert a USB stick (Tried both San Disk Cruzer Glide/32GB and Kingston DT50/16GB) Drive formats fine, shows amount of space. Have 16 channels set up to record. Arm Record and
hit play/pause button. Starts recording and counting down time left, then I hit the stop button and appears to stop, but shows busy. Waited a while the first time and just said busy till the drive
filled up. Second time, same results, so checked the disk utility tab and it appears after I hit the stop button it is still recording, keeps on going till the drive fills up then stops. Only other
way to stop it is pull the USB Stick. Appreciate any assistance. Read through everything, but maybe missed something.
Did you try to Pres the Record butane a
Second Time? To Stoop the Recording?
Yes, all the start/pause/stop/arm buttons on the multitrack record window don’t respond. Maybe USB flash drives I tried don’t work. Couldn’t find the exact model for either
on the testing result spreadsheet. Will try a different flash drive today.
