I installed 1.3.1 this morning and I am happy to report one successful gig with reliable network Ipad control without any freezing issues. Thanks A&H team! This is such a relief! I’m more hopefully to see continued successes now moving forward. Ironic for you to release the firmware update on a Friday, but I’m content and grateful despite the timing. In my case, it came just in the nick of time.
Unfortunately I’ve found a bug in the mix stereo aux: they don’t change the naming of the single aux send in this section when you move from a scene to another, you need to stereo link and apply to “update” and display the correct aux name.
I’ll open a ticket!
Thanks @fabry - We have noted this as a bug. It’s not unique to V1.3.1, and presumably has not been thought of as an issue previously as mix config is saved at show level, so it’s generally set before storing or making any changes at scene level.
Due to an inadvertent flip in the DEEP Peak Limiter 76 black-face and silver-face GUI’s, there is a V1.3.2 available now.
This was a very (very) low risk change and only required a single day of testing. Hence the ultra rapid turnaround…
There are no other differences between V1.3.1 and V1.3.2.
Thanks Keith! I have only been checking the troubleshooting forum to see if there was any updates on the USB streaming issue. I had no idea 1.32 was out.
So far so good on the streaming front. Fingers crossed. Thanks A&E for all your hard work and getting this firmware out super quick.
You should need 1.3.1 to upgrade. I did one the other day from 1.2.2.
Probably not correct on the thumb drive or something else. Follow the instructions exactly. Unzip the file. Put the .bin file on the root level. No other versions showing. Make sure you downloaded the correct version. There is a different one for each console size.
