SQ- functions Wish list :-)
  • Stereo channel assignment:
    should be saved on Scene level as well, not just on show level.
    I will have an evening (show file) with several bands where DI input channels will vary between mono and stereo. I can not change showfiles for each band at the event because there will be other signals playing in between band changes, so for each scene i have to Gang, or manually change Stereo channels in the menu. I need Stereo channel configurations to be part of a scene.
  • FX channels:
    The quick access is wonderful since you added that. The PEQ is already available on each channel. However, i would like to be able to access a compressor on each FX channel as well, if processor power still allows for this.
I believe that if you safe the channels that you need to keep playing through band changes, and you can mess with everything else and change scenes as you need.
