Hi all,
It would be great to have a visual indication of what outputs are already patched. It’s clearly visible when you patch aux 1-8 to local output 1-8, because in the same tab a coloured band is shown to mark “occupied” outputs.
But when you then change e.g. to the Direct Out tab, the coloured markings from the previous tab are gone and you can no longer see which outputs are already patched. It only shows the coloured markings for the currently selected sources.
Same goes for inputs which already have been patched.
Best regards,
Rob
