I’m considering an SQ and want to understand a channel’s mute button behavior on sends. Of course, the mute button stops sending the channel to the main mix and any post-fade auxes, but what about pre-fade auxes? Does it also mute for pre-fade auxes? Or are pre-fade auxes independent of the mute buttons?
The technical datasheet seem to say, that prefade also gets muted.
It does look like pre-fade sends are also muted based on the diagram. Is someone with an SQ able to confirm?
It would be a deal breaker for us if they don’t get muted given how we use pre-fade sends to stage monitors, so I’d like to be 100% sure. Thanks!
Yes, I can confirm that the diagram is correct and that the pre-fader-sends muted using the mute buttons also on the SQ.
Late to the post - Mute buttons are Global - Mute is anything downstream of the channel.
After getting an SQ, I confirmed as well that the mute buttons are global and kill all pre-fade sends as expected.
