SQ - Output polarity flip. (MATRIX)
I think this feature is very necessary, to be able to adjust subwoofers in phase, cardioid, etc.
And a few more matrix, if that’s possible.
it’s already there under the processing tab.
Hi Mick,
Attention, you are wrong!
This Polarity swap is ONLY for the Ext-In!
NOT for the matrix bus Signal!
→ See the block diagramm
+1 for polarity flip on outputs - it’s also really useful for cleaning up monitor/main alignment
interesting.
Thank you for clearing that up
+1 to at least have polarity flip as an option in the routing or IO section for outputs
I’d like to see the stereo processing like in stereo channels for stereo busses…
A
+1
+1 Essential for setting up comprehensive monitoring in the studio.
+1
The function of reversing the polarity of the phase is very lacking, as well as the delay function on the channels of the matrix
+1
Absolutely +1
Today we’ve had a bad surprise, we needed to invert the polarity of a delay PA that have had inverted Polarity between the main PA, unfortunately the Matrix Polarity button doesn’t do anything at all ?
Phase reverse XLR barrel?
D.
+1
It’s an essential feature
D.
I’ve carried a couple of those around for many years!!! Very well marked as to what
they are!
+1
Big +1! I always carry polarity inverting cables, but having it inside the console processing would be far superior!
+1
+1
It could be really helpful to manage small PA !!!
+1. So I don’t have to use phase reverse barrels on my Thomann Achat 115m when used with other boxes (because they’re internally wired reverse-polarity!)
