Often I am monitoring an AUX out for a Stream / broadcast feed - often some mild compression is needed and usually a big chunk of make up gain to bring the AUX out up to the Db Range I like to work in ( yes “track slammed” more so than intended for transmission - more competing with other internet volumes)…
So fo r me the PFL trim operates in reverse - I would benefit by being able to either boost the PFL Listen or Reduce the AFL mix listen.
of course so when I PFL a mic - its not significantly lower the my broadcast mix.
Cheers
