I am looking at the SQ Rack for our IEM mixer and wondering if others have been using it with the SQ4You app. The main question I Have regards to the limitations of how many people can access the app at one time, the manual says maximum of 8 at one time. We have a band from 10 to 13 people who will need access via the app, has anybody being using the system with more than 8 people at a time, Thanks
The system definitely has an 8 device hard cutoff. It doesn’t matter if we are talking about OEM or third party apps, they are all subject to this limitation. In other words, there is no “fudging” things to get a 9th device, etc. When a 9th person connects to the system with their device, it will generally “kick off” one of the existing connections so that there are only 8 devices connected at a time.
That being said, we are talking about unique device/software connections, not an actual aux buss limitation. In other words, more than one person can use/share a single device/software connection and just switch the app to control “their” aux buss/monitor mix as needed. Someone else can then use the app, change it to control “their buss”, and make changes to just their mix. It’s obviously not the most convenient way to handle things (it would be better for each person to have their own dedicated device), but it works. Obviously people close to each other are the easiest to share devices. Perhaps all backup singers share a device, or the brass section of the band shares, etc, etc, etc.
Adding some of the ME system would get your stationary needs met, but it looks like the only way to access the ME hardware is with an external stage box. Kind of dumb, since one of it’s suggested uses is for IEMs.
