SQ - Subgroups
How do I create a subgroup (NOT DCA) that will act as a bus that I can route to the main L/R send? For example, I am wanting to have a drum buss that is EQ’d and compressed that I can blend with the original drums in the mix.
I basically want to be able to assign certain channels into a buss that I can process with EQ and compression separately from the processing I do on individual channels.
When on the main fader, use the assign button and de-select the channels you want to route via the group.
As default “aux” 9-12 are set up as four stereo groups, choose one of these and assign the channels to that group.
Default you have the group masters on layer D
