Anyone have already used the waves system (on other desks…)with the differents solutions ?
Is it conceivable to use the waves rack on pc for live ? Or absolutely we need the waves server?
I have used Waves plugins live starting with the X32/M32 via USB. Then I moved to X32/M32 via MADI. Then to X-WSG card. Then to GLD with Waves card.
The short answer is “no”. It is not conceivable to run Waves plugins without a server, unless you plan on using it only for recording or using delay or reverb plugins which, by their nature, are delayed. Otherwise, there is too much latency.
I did play with it on the SQ without the Waves card. Not good for live. I have the Waves card on order now.
I use an Extreme Server (because I had an implementation of LV1 prior to my dLive), but in many situations, you can get away with an Impact Server if you’re not planning on taxing it too much.
You definitely want a server to go along with the Waves card.
Going over regular USB causes way too much latency, and on top of that you are at risk of software/computer going down which will completely eliminate your audio stream.
With the server, if the software (Multirack SoundGrid) crashes, audio will continue on with the server hosting the streams.
Also, with a server, you can bring your latency down to 0.8ms, which is possible to mix IEM’s with.
I have zero experience with the SQ series and a SoundGrid network as it isn’t out to the public yet, but from my previous experiences on SoundGrid networks, it’s basically a “don’t leave home without it” scenario.
