SQ with DX Expander And Dante Card
I am planning on buying an SQ. The plan is to also use the ME monitoring system and a Dante card.
In the future, if we wanted to also add a DX stagebox, would I still be able to hook up the ME monitoring?
I know the DX stageboxes don’t support ME. I was thinking that I could use the DX Hub, but then realized that doesn’t seem like it will work as it only seems to support DX (hence the name).
Is my only option for a stagebox in this case to either get one of the AB stageboxes or DT stageboxes?
Hi
Check this doc to see the supported SLink connections https://www.allen-heath.com/media/SLinkConnections_V1_5_0.pdf
If you use dante card (but actually it’s very hard to buy one) you can use DT168 stagebox on dante card and Me system on the SLink port (need 2 cables).
You can connect Me system directly on 48 KHz stagebox AR2412 (Me port) and AB168 (extension port) and 96 KHz stagebox GX4916 (Me port).
Thanks for confirming things, Flo84!
