SQ5/6/7 + SQ-Dante + DT168
I wonder which latency I could expected when using a SQ together with a SQ-Dante and a DT168 ? I assume the dante latency can be set in the dante controller, but can the SQ-Dante together with two DT168 run at 150 us ?
On the other hand: the SQ-Dante card can be set to run in 48 kHz. Are there any numbers how this will affect latency ? And does preamp control from within the SQ still work then ?
Thank you
PS: and just to raise a voice: I wish the devices like DT168 and DX168 would be available in a 2U chassis …
