SQ5 And Waves Aux insert options
Hi SQ Users.
I have the following:
SQ5 with Dante Card
Hear Tech Dante to Soundgrid convertor
Soundgrid system (server, multirack etc)
As all my feeds come from Dante, I plan to route these to soundgrid, through superracks, then back out and Dante into the SQ. This should work fine for channel processing.
My question is Bus processing. I know I can send e.g. AUX 1/2 out into Dante world and then get that into sound grid. I can then get out of that particular rack back into Dante.
But there seems to be no way to insert on a Aux on the SQ :frowning: Is this the case? If so how are people doing waves bus processing? Currently I can only think of returning them on the ST2-3 inputs or
spare channels. Am I missing something?
Thanks for your help. Love the SQ, just want to play with adding my waves system now.
Jon
I insert my Waves MultiRack on my buses like i do my Inputs. On the Process screen under Gate above PEQ is the insert button. Select it and there i select the IO i send and return.
You have the inert point just before the GEQ on the Mix processing screen
