SQ5 automatic Startup
Hello guys
it is possible that the SQ5 during startup loads automatically (without any user interaction) an saved scene.
target is to have after every startup the same default configuration loaded.
is there somehow an posibility to do that?
thanks
Best Regards
Yes
See page 89, and the top of page 90 for user settings.
@MarkPAman , seems to be pages 91 → 92
pages
Image link in below post seems not working, so I’ve uploaded here
hello all
thanks for reply.
unfortunatelly there is a manual action needed (active login)
the SQ5 is placed in a technical room and can be switched on via a special switch in the gym from the trainer with a key.
it would be great if after booting the console login a certain user and load the linked default scene without any interaction on the SQ5 itself.
thanks a lot
Create a user on the SQ that has no password. Log in with that user just prior to shutting down, and the mixer will come back to that user on the next power on cycle without prompting for a PW since there isn’t one.
Hi Scott
thanks that work.
is it also possible to load directly (without any interaction) an certain configuration/scene?
thanks in advance
I was looking for more information on this topic.
We too would need it to load a scene on startup without needing the confirmation setting
Is it possible?
Thanks in advance!
As already described above, set a user with no password and set a startup scene for that user.
Make sure the scene confirmations are set to off. Setup > Surface > Preferences
