SQ5 - LifeProfessor 2 via USB on M1
Hi guys,
I already saw several setups on Video using LifeProfessor as Plugin Host on the SQ 5, but I haven’t seen anyone using it just over the USB Port.
So I tried it. and it did not work…
I connected my McBookPro M1 via USB (dongle in between) straight into the SQ5.
The SQ USB Inputs showed up in LP2 and I did a simple 1 to 1 Routing and Inserted the USB I/O into a Mic Channel. Unfortunately, it wasn’t sending Signal into the LP2 chain and back.
And now I wonder why cause I’m pretty sure I did everything right.
The question, is there a problem with USB 2.0 port and the new McBook Ports?
Or do you guys have any other Idea what was blocking the Audio coming thru ?
Thanks a lot in advance
Curly
How did you route the channel insert on the SQ?
@the1curly
It is definitely possible to use SQ’s built in USB interface with Live Professor on an Apple silicon Mac, so as @nottooloud suggests, double check the routing.
You could also check the security/permissions in macOS and make sure Live Professor can use the microphone (which equates to ‘can use audio I/O’).
The main thing to be aware of when using USB for external FX is the latency.
We covered this in a live stream that can be rewatched here - https://www.youtube.com/watch?v=LjPXMSlW8aM
Cheers,
I haven’t tried it, but I would guess you’d need to use a tie line from the preamp to the USB, and then select the USB as the channel input. Don’t know how you’d control the gain on the preamp, though.
@keithjah, what’s the correct way to do a USB channel insert?
@nottooloud
Any external processing can be patched directly from the insert point of the channel in the processing screen.
You can patch to/from any combination of analogue or digital sockets :slight_smile:
What you’ve suggested would work if you wanted to process pre-all-processing. Both would add the same latency too, just at different points in the signal path.
Oh, and you can adjust gain for any system socket with a preamp from the I/O screen without patching to an input processing channel, just touch the input socket number!
Cheers,
Hi guys,
thanks for all, i have a follow up and i am realy ashamed that i havent switched from SQDrive to USB. I dont know how this has passed my attention, classic state of “i did “everything” right i dont know what to do, lets search for an edgecaseszenario” …
Again thanks for your messages, much appreciated.
So far it works very well so far. LP2 shows me approx. 6 ms Latency (3 In 3 Out ) on 96 Samples Buffersize.
Ill try and test it now also for stability, and what works and what not before i try to implement it in my work.
Best
Curly
