I have a SQ5 and recently added a ME-1 unit. While I get the channel names sent to the ME-1, I am having some issues:
- I am not getting any audio to the headset or the mono line out - even though I can see audio signal on the ME-1 level meters.
- I do not see the SQ5 in the ME-1 system settings - I believe the SQ5 name should be in the ‘Unit:’ field.
- Most importantly, I am getting a red blinking light on the SLink port.
My path is as follows:
- SQ5 (v1.6)→SQ5 SLink NIC → port 8 on a Layer 2 Netgear GS316EPP PoE data switch→ ME-1 (v1.17-Rev61242) via port 9 on the same Layer 2 Netgear GS316EPP PoE data switch.
A couple of notes:
- It seems like I get control data but not audio data.
- The SQ5 SLink is set to 100-Full.
- The sample rate is set to 48kHz.
- All cabling is Cat5e.
- The Layer 2 Netgear GS316EPP PoE data switch has nothing special configured (flow control, error correction, etc…). I made a point to verify anything like this is disabled (most were disabled by default).
- While there is a ton of information on how to configure the ME-1, I am not seeing a ton about the correct SQ5 configuration for the ME-1
- What I have configured on the SQ5 is: I/O→Outputs→ME tab→IP Direct Output and then selected the appropriate patching. I can see this part working because the ME-1 gets channel names.
- I have a Dante card and two DT168s (I mention to be thorough but I do not believe this is related).
What I have tried the following but no luck so far:
- Changed the sampling rate from 96kHz to 48kHz. I know the SQ5 internally uses 96 kHz. I only saw a sampling rate setting for USB, Dante I/O card and DT168 stage boxes. Maybe there is a setting I missed?
- Replaced data switch
- Replaced both Cat5e cables
- Used local PSU
- Upgraded firmware of the ME-1 even though it had the same load.
- Set ME-1 data port to 100-Full.
- Direct connect from SLink to ME-1.
Any suggestions?
