SQ5 Mixminus&PFL delays
hi,
in this times of covid, the sq5 is getting used as a broadcastdesk , especially for this purpose it would be great to have a mix minus function.
Also it would be great to listen to the masterbus PFL.
what you mean with this?
Sorry! i mean listen to the delays on de masterbus!
still don’t get the point, explain some more
when you put a delay on the masterbus(also for groups, matrixen etc) for example syncing audio to video, you can’t hear the outputdelay on the pfl
Do you have the “Output AFL” setting to ON? I can’t recall if this is in SQ off the top of my head, but if you monitor the outputs as AFL I would think you would also hear the delay. I’m not near my SQ right now, but check your PAFL settings in the setup menu.
You can delay the PFL separately if needed.
I do this for live work so the sound in my headphones when I put them on is aligned with the arrival of the sound from FOH.
