I am very new to digital mixers and the SQ6 in particular. We have just acquired the SQ5 and AR2412 for our church and I am in the process of learning it and setting it up at home prior to installation.
I am sure it’s operator error, but I can’t see how I can route say Mix 5 to the USB drive so I can have one mix for the church on LR, and a separate mix for the stereo recording.
To patch Mix 5 to the SQ-Drive stereo recorder, go to IO > Outputs > Mix Out on the left and USB on the top. Now patch the L & R of the mix bus to USB 1 & 2. If you only have a mono mix bus for recording, you can patch it to both USB 1 & 2.
OK, this is where it seems odd. I do that and scroll down through the sources, but can only see Mix 1 LR, Mix 2 LR and Mix 3 LR and that is the bottom of the page.
Sounds like you’re actually looking at the Matrix Busses. The Mixes 1-12 can be either auxes or groups and appear further up the list. In the end it depends, what kind of mix you are setting up for recording. If it’s an Aux, you need to select that Aux to be routed to USB…
