SQ6 Aux Mix Issue
I have perused through my routing and patching and have been unable to find the issue. What’s happening is Channel 1 will only turn to down to a certain point in Aux 1 before staying at a certain volume. The issue is the same with Aux 2 concerning Channel 2, Aux 7 and Channel 7, etc. What could be causing this?
Where are you turning the level down at, at aux level when in sends on fader mode?
Are you directly listening to the Aux out?
Are they pre or post fade auxes?
Hi Harvey,
→ maybe you patched the input source to a second channel?
→ maybe you’ve patched the inputs to the Ext-In of the Aux busses?
→ maybe you set up groups, and they send some signals to the auxes?
Be aware, even when the channel or group is not part of any fader-layer it will work in the background and still sending/processing signals…
greetings,
dd
