SQ6 Dante inputs
I am relatively new to Dante, I have a new setup that is giving me problems. I have an A&H SQ6 working with a pair of Renkus Heinze P3-64s and a pair of Renkus Heinze SA28 subs and a HP Laptop running Dante Virtual Soundcard. The Dante devices are all set to 96Khz sample rate. The SQ6 is set to clock the IO port i.e. Dante card. Dante Controller has the SQ6 as the preferred master. All firmware in Dante devices and the SQ6 are current. Routing in Dante Controller is A&H SQ6 transmit 01 and 02 to RH P3 and RH SA28 01 left and 02 right, that all works.
Laptop out is routed 01 left and 02 right to A&H SQ6 in 39 and 40 in Dante controller, both have green check marks and correctly identify the subscription. The SQ6 routing has IO port (Dante Card) routed in 01 and 02 to IP39 and 40. I get no signal indication at either ch39 or 40 regardless of gain setting. I tried connecting the laptop Virtual soundcard to one of the Renkus Heinze P3-64s and it worked. However I get no signal at the SQ6. I am using a Ubiquity USW-Pro-XG-24-POe switch. All Dante devices are showing 1Gb connections. The IO card (SQ-Dante 64x64) is set as clock master. I still get no audio at the SQ6 inputs. I cant help but thinking I am missing something obvious, any ideas?
OK so it was something stupid, I was relating the SQ6 matrix to the Dante Controller matrix and setting the assignment from my laptop transmit channels to 01 & 02 in the SQ6 matrix instead of the input channels I had picked in Dante controller, the matrix if rotated 90deg clockwise from the Dante matrix, duh!!
I’m not sure what audio you expect to RECEIVE into the SQ over Dante. What audio do you expect to see on channels 39 and 40 given there is only speakers connected to your Dante network?
OP has its laptops ch 1/2 into Dante 39/40. If I read his text correctly:
It seems like he has things patched the wrong way around. I guess he should patch Dante I/O 39/40 to a channel. Not Dante 1/2 to input 39/40.
I hope my description was clear enough. Good luck!
Rob
Dante is NOT plug and play. My unsolicited advice is to look to the huge amount of content on the Audinate Dante website (https://www.getdante.com/) and take advantage of the training offered. They have three levels of “certification” and Level #1 will go most of the way to making your travels with Dante way less frustrating.
Just my $.02.
D.
