Hi everyone,
I use a SQ6 and the GX4816 is connected in the S-LINK mixer.
Actually I need more inputs, less than 16 but near to me.
Can you help please? What should I buy?
Thanks a lot.
Laurent.
Hi everyone,
Thanks a lot.
Laurent.
You already have 24 inputs on the back of the console.
Hi SteffenR,
Yes, but when I connect the GX4816, in the mixer, in the I/O screen,
it disable the local inputs.
it’s as if I could no longer use the local inputs once the GX4816 is connected and configured.
Can you tell me if I’m setting wrong?
@SPH1X
Connecting an expander (or I/O Card) will not disable any other input or output sockets.
It will simply add more input and output sockets to the system, which can then be used however you wish.
What it will not do is change the number of input processing channels available. The SQ always has 48 of these, whether you have expanders connected or not.
Where you could be confused about ‘disabling the local inputs’ is that to patch all the available input sockets from the GX4816, you will be patching SLink inputs 1-48 to all input channels and overwrite the default local patching.
Personally I find it easiest to consider the input sockets, input channels and also channel strips on the surface as 3 separate things.
The 48 input processing channels in the core can be sourced from any available input socket - local or remote analogue, or digital (USB or I/O cards)
Input channel strips to control the processing and routing of these can then be placed in any position on any layer of the surface.
Hope this helps,
Ok Keith, thanks for your reply.
So if I understand correctly. Even if I add a 16/8, it won’t work,
the SQ6 will remain at 48 inputs.
@SPH1X
Correct - There can be over 300 input sockets in an SQ system, but the number of input processing channels is always 48.
You can sacrifice Groups to get some extra inputs to the mix and then use Group/Mix processing, but obviously this will eat into your available mix count instead.
For more input channels, you’d need a ‘bigger’ (not necessarily physical size) mixer, like the Avantis (64 input processing channels) or a dLive (128 input processing channels)
