I’m using multiple Vocal Tuner instances on an SQ6+, all following the Global Key/Scale.
I’m trying to find the best practical workflow for changing the Global Key and Scale between songs during a live show.
I have tried using the Vocal Tuner in Chromatic mode, but I don’t find this reliable enough for natural correction. As I understand it, in Chromatic mode the tuner simply corrects to the nearest semitone. This means that if a singer is far enough away from the intended note, the tuner can potentially correct perfectly to the wrong note.
For that reason, I think using the correct Key + Major/Minor scale for each song is really necessary when the tuner is intended to help with more than very small pitch deviations.
The problem is the live workflow.
On the SQ6+, the Vocal Tuner parameters currently available for assignment to the Soft Rotaries are only:
- Correction
- Retune
- Transition
- Reference Pitch
Global Key and Global Scale cannot currently be assigned to the Soft Rotaries.
During a show I normally spend most of my time on the Processing/PEQ screen. Having to go into the RackUltra FX/Vocal Tuner screen before every song, change Global Key/Scale, and then return to Processing is not very convenient.
So my question is:
What is the intended live workflow for changing Global Key and Scale quickly between songs without having to open the Vocal Tuner screen every time?
If there currently isn’t one, I would really like to see Global Key and Global Scale added as Soft Rotary parameters.
There is one complication with using a rotary directly: when changing, for example, from G to D, I would not want the tuner to become active successively in G#, A, A#, B, C, C# etc. while turning the rotary — especially if somebody is still singing or speaking into a tuned microphone.
Perhaps the button underneath the Soft Rotary could be used as a confirm/apply function:
Rotate = select the next Key/Scale
Button = apply the selected Key/Scale
That would make it possible to prepare the key for the next song safely, while remaining on the normal Processing screen.
I’m curious how other engineers are handling this with Vocal Tuner during a live show.
